savage not getting fuel.
did you check your fuel line and presure tube for any leaks in them? or the fuel tank lid to see if theres any thing in it making it not hold preasure? cracks in the tank ect... also the exhaust coupler make sure its tight so its not leaking air out of that .... check for debree in the bottom of the tank .. filter might be clogged .... these are just things to check to start with .. hope it helps ..
it sounds stupid but its easy to do. make sure your fuel lines aren't mixed up. if they are on right then pull the lines off the exhaust and carb and blow into the pressure line coming off the cap and fuel should come out of the other line.
