Hoagie
- Location
- South Dakota
haven't pulled it yet. Stay tunedIt's ether a savage 21 or 25. Whats stamped on the side of the block?
Not a Nitrostar S-25 (They had a purple cooling head..)
May be F4.1 or F4.6.
But looking at the Savage I say it is a 25 with some after market stuff on it.
Yea I had it turning counter clockwise but under throttle it would go in reverse. So would the transmission cause that? Plus I am fairly new to monster trucks. Do all the steering servos suck? They can barley turn the tires back and forth. What is a good servo to use?F4.6 .
The drill has to turn counter clockwise to start the engine..
The clutch bell is spinning counter clockwise.Hmm. The transmission wouldn't cause that.
To be sure, if you look at the clutchbell from the front it has to rotate counter clockwise.
Has this happened once or several times?
Stock steering servo's do suck.
What servo do you have?
May also be that the servo saver is loose.. Check the spring.
yup. I suckCant tell from your pic, but is it possible it has a reverse module on the transmission and that is in reverse not forward????
