Rotostart tool
ya them chargers only charge at about 1 amp or so, it may take 12 hours or more to reach full charge
As long as you are VERY careful and know that nothing is wrong with your motor you can use a drill with the roto-start bit.
>note: this message does not condone cranking up the torque on your drill and demolishing your new motor, use at your own risk<
lol
If it's not the battery and the motor is that new, you can also loosen the glow plug just a little to help crank the motor. Then, as soon as it fires, pull the igniter off and tighten the plug back up.
