Picco P3 Need Help flywheel
fredsthao21
I just bough a Picco P3 and need help finding a flywheel, clutch whole assembly that will mount up to my stock savage spur gear. I believe the spur gear is a 34T
All your stock parts will work, just swap them off the old engine and your good to go. You may want to upgrade to some aluminum shoes if you have the composite ones.
I bought DYNP5184, Mugen Clutch Spring 1.0mm (3), and the HPI 17t Vented CB and HPI 34mm Flywheel.
The Clutch springs do not fit properly under the HPI pilot nut properly. Do I need a different pilot nut? I have the HPI clutch springs but they don't fit the Dynamite Shoes very well. I would just like a recommended setup from someone other than stock.
I run the stock Savage flywheel, Dynamite Max-Life shoes, Mugen 1.0mm springs, Mugen clutch nut, and HPI 15t clutch bell on my Picco P3. This setup works well, 3 gallons in and I haven't had to mess with it at all. You'll want to use a larger CB if you are running stock diffs.
