One Way Bearings and I do not get along...
Alberta, Canada
So I head out to one of my newly discovered bashing spots. Get all settled, gas up the Savage, pull out the roto start and glow plug ignitor. Had it running two days ago with nothing but success. Go to fire it up, almost starts the first try. Try it again and the one way bearing is toast as it spins freely...is there a trick to making one way bearing last longer? Maybe going to a pull start instead?
:thinking:
YES! With the pullstart installed, the external owb like is on your truck (I'm assuming) will easily last 5 times as long. Porbably more. If you get a really good one and clean it a lot it may last as long as the engine.
Its possible
