Can WD40 work? How can I be sure of the size then. SorryUsually the one way bearing gets saturated with oil causing it to slip, the simple solution is to clean it with motor spray or denatured alcohol and lightly grease it to let it grip the shaft again...as for the size, there are different sizes used for differing things.....some 1 ways and starters use a 12mm bearing.....
Sorry i don't understand. You mean nitro fuel?I use fuel.
Brake cleaner is bad for most RC stuff. It dissolves plastic. Steer clear of that.Break cleaner?
I thought a 4.6 with rotostart doesnt have a OWB. It's in the wand.
