Nitro Star F.5.9
Yeah I agree. I have leaned the engine out and will try again today. Update later. Can you attach vids on this forum?
Chris.
Latest update. Once warmed up and primed engine starts first time no problem. Idles ok through a whole tank. Thing I don’t get is that the motor is still running exceptionally rich. I have leaned it at least a turn and a half from factory settings. The max engine temp is 52degC and one tank produces this much exhaust oil. I can only think factory default is waaaaay too rich.
factory setting is just a base to get it to start, then you need to tune for optimal power and running
Latest update. Starts and runs no problem. But, I am leaning her out way leaner than factory settings, ( Engine is brand new), and still the temps are only around 50degC. I can put my hand on the head whilst running. Even if revved up temps don’t get above 50c. How low do I have to go on the main needle.
Very strange engine temp not getting above 52c especially with a new tight engine!
Usually harder to keep temp down when breaking a tight engine in, are you running 20 or 25% nitro & what g/plug are you using?
factory settings are just that, you may have to lean out (the big needle at the top by the carb inlet) possibly a turn and a half, but just lean out (clockwise) 1/8 of a turn at a time until you have power but mind you should always still have a smoke trail at wot whilst driving
Hi I am using 25% Nitro and an R5 glow plug.
