New Mini-LST2!!!
Memnoch
Loganville, Ga
Losi 1/18 Mini-LST2 Monster Truck RTR
From Losi:
The Ready-to-Run Mini-LST2 from Losi® is designed and modeled after the LST2, Losi’s top-of-the-line monster, it’s truly the monster of the mini class. Featuring a dual-deck aluminum chassis, oversize adjustable aluminum-body shocks, a 4-wheel drive system with 3 differentials, dual high-torque Frenzy-370 motors, complete ball bearings and the Losi radio system with 2.4 Ghz DSM® technology uses no crystals or channels. This innovative radio system allows you to run your Mini-LST2 with other vehicles anywhere, anytime, without worrying about interference. With these features the Mini-LST2 represents the ultimate mini truck experience.
Key Features:
Losi Radio System with 2.4 GHz DSM Technology
Metal Ring and Pinion Gears
Aluminum Oil-filled Shock Bodies with Threaded Adjusters
Chrome Dish Wheels with mounted Mini-ATX Tires
Twin Frenzy- 370 Motors
Twin Steering Servos
Dual Deck Aluminum Chassis
4WD with Slipper Clutch
Gear Cover that allows use of the Mini-t Dual-Disk Slipper
Factory-decorated Mini-LST2 body (available in Red, Blue and Silver
Complete Ball Bearings
Losi Dual-Motor ESC
7.2V 100mAh Ni-MH Battery Pack and Charger Included
4 AA Batteries for the Transmitter Included
Specs:
Scale: 1/18
Length: 10.6" (271mm)
Width: 8.2" (209mm)
Wheelbase: 7.2" (185mm)
Weight: 2.2 lbs (1000g)
Chassis: Dual Deck Aluminum
Suspension: 4 Wheels Independent
Drive Train: 4WD with 3 differentials and Reverse
Tire Type: Mini-Zombie Maxx
Motor or Engine: Twin 370-Type
Speed Control: Dual Motor ESC with Reverse
Radio: Losi Pistol Radio with 2.4 gHz DSM Technology
Servos: Twin Steering Servos
Batteries: 7.2V 1100 mAh Ni-MH and 4 AA (for transmitter) Included
Charger: Included
Kit/RTR: Complete RTR
Shock Type: Oil-filled, coil-over type
Body: Pre-painted body (Red, Blue or Silver)
Ball Bearings: Complete Set
i saw that the other day, looks nice and with steel diff gears should be more durable than the last one, cant wait to see one with dual 6800kv mamba or better brushless setup.
One of my mates is getting one of these when they arrive here. It should be good but it will be great when he upgrades it to brushless. It wont be a dual brushless though. It still won't out run the mini-t though, it's fastest car in my garage.
