Memnoch
- Loganville, Ga
Losi 1/18 Mini-LST2 Monster Truck RTR
From Losi:
The Ready-to-Run Mini-LST2 from Losi® is designed and modeled after the LST2, Losi’s top-of-the-line monster, it’s truly the monster of the mini class. Featuring a dual-deck aluminum chassis, oversize adjustable aluminum-body shocks, a 4-wheel drive system with 3 differentials, dual high-torque Frenzy-370 motors, complete ball bearings and the Losi radio system with 2.4 Ghz DSM® technology uses no crystals or channels. This innovative radio system allows you to run your Mini-LST2 with other vehicles anywhere, anytime, without worrying about interference. With these features the Mini-LST2 represents the ultimate mini truck experience.
Key Features:
Losi Radio System with 2.4 GHz DSM Technology
Metal Ring and Pinion Gears
Aluminum Oil-filled Shock Bodies with Threaded Adjusters
Chrome Dish Wheels with mounted Mini-ATX Tires
Twin Frenzy- 370 Motors
Twin Steering Servos
Dual Deck Aluminum Chassis
4WD with Slipper Clutch
Gear Cover that allows use of the Mini-t Dual-Disk Slipper
Factory-decorated Mini-LST2 body (available in Red, Blue and Silver
Complete Ball Bearings
Losi Dual-Motor ESC
7.2V 100mAh Ni-MH Battery Pack and Charger Included
4 AA Batteries for the Transmitter Included
Specs:
Scale: 1/18
Length: 10.6" (271mm)
Width: 8.2" (209mm)
Wheelbase: 7.2" (185mm)
Weight: 2.2 lbs (1000g)
Chassis: Dual Deck Aluminum
Suspension: 4 Wheels Independent
Drive Train: 4WD with 3 differentials and Reverse
Tire Type: Mini-Zombie Maxx
Motor or Engine: Twin 370-Type
Speed Control: Dual Motor ESC with Reverse
Radio: Losi Pistol Radio with 2.4 gHz DSM Technology
Servos: Twin Steering Servos
Batteries: 7.2V 1100 mAh Ni-MH and 4 AA (for transmitter) Included
Charger: Included
Kit/RTR: Complete RTR
Shock Type: Oil-filled, coil-over type
Body: Pre-painted body (Red, Blue or Silver)
Ball Bearings: Complete Set
From Losi:
Key Features:
Losi Dual-Motor ESC
Specs:
Scale: 1/18
Width: 8.2" (209mm)
Charger: Included
