The OS #8 will work but it is a "short" plug. It will not sit flush with the bottom of the dome and will lower compression a bit resulting in a little less power, not the best choice but will work in a pinch.
If you don't use a long plug your engine will run hotter with no increase in performance. Been there, done that. Run a long plug or your engine will suffer.
Call Axial and they will tell you the same thing.
