my engine isnt getting fuel
biggen3.5
so when i try to prime it it doesnt pressurize the tank and yes I'm priming it right but the tank just isnt pressurizing at all
are ya usin a primer in the tank ? if so and it aint workin , maybe turn the engine while covering the exhaust for a second or so and see if that works.... if that don't work check the fuel line for a leak....
Also could have a leak in the tank. You can also take the pressure line off the exhaust and blow in it until you see fuel going up the supply line.
It needed a header gasket from the block to the header so the pressure line from the e haust wasn't getting enough air to pressurize the tank
