motor help
killergsxr1
well i made the mistake of buying a axial .28 and as normal the front bearing is leaking and giving me a lean condition even tho its super rich and the motor is sealed..my question is what bearing do i replace it with to fix my problem??
wow i keep hearing about the axials, I'm just wondering why they haven't corrected the problem yet?.. someone will be here to help ya shortly I'm sure!!
LOL you do know the bearing does not seal out the air. this is a mith. on road mills you can see light threw... Think that would be a air leak right. ? Wrong... bearing does not seal out anything. Its all in the block. rubber seals on the bearings keep out dirt not air.
Try to lean out your mixture, you may find that the leak issue goes away. Running a super fat tune will cause more oil to go to the front bearing, there is a little hole that goes through to the under side of the carb (in the block) if too much oil gets to the front, it will leak out and not get sucked back in. Try that and let us know what happens.
the needles are in stock settings..if i even turn the hsn an 1/8 turn it leans so bad the brakes almost cant hold her still but tons of smoke is coming out the exhaust..ive tuned tons of motors and this thing goes lean with any needle being touched..but its dumping fuel out the pipe its so fat.and the motor is completely sealed as i do all my motors thats why i thought it was the bearing plus it seeps fuel out from it to..don't no where to go next but the garbage can!oh yea tried fuel lines,new tank(not a savage stock tank),different plugs,different fuel...I'm lost..what plug do you guys recomennd
