Modded Mach .28 pics?
TommySavage
Hello
I'm going to mod my engine and need some pics if anyone have done it?
Would need sleeve and crankshaft pics.
btw, it's a Dynamite Mach
I have done an Axial 28 which is in the engine section as well. This process is actually fairly simple. Just make sure to get some of the rubber polishing tips ordered as you will be unable to find them locally.
we can give advise on your sleeve, just post pics of it before you mod.
By seeing the fuel and air pattern youu can determine where to cut.
Exactly, I'm with crash. I have never had a Mach apart so please post picts. It also helps alot if the motor has been ran some before as they will be Lines or marks for the most part showing some signs where to do some work.
Take it apart and show us picts. don't touch the Exhaust side. Also get pict of the rear end of the crank and some picts of the hole in the side of the crank.
It's a simple 3 port engine so I think a can port the sleeve on my own,
but I'm not really sure what I should do with the crank?
Posts pics as soon as I can.
on the crank:
if it does not have scoops add them
smooth out the throat
polish it up
IMO
note: the crank in my avatar had no scoops, I added four
