Bankrupter
- Thread starter
- #61
OK got it in... failure! I need wider poly to form it. Just too tight to the frame to make it work.
So till order 2 gets here...
Hey Justin you think a 24x24 sheet of poly will be ok for a XL body?? and 0.04" thick ?
May not get the ends. sides will be fine.
great idea with the cold water. in hind site, to support the body, you might be able to use some sand. put sand in a cardboard box and wiggle the body into the sand. It will conform to the body well & support well.
pretty kool project.
yep worked out good.. WAY too many holes to drill by hand though, then bevel out.
BOX :nutshot: ME
I know it's too late for this info but it might be helpful for someone else, you can buy a countersink attachment to go on a drill bit to do both at the same time...Just FYI...
