losi lst xxl or hpi bigbore shocks for flux xl
unicorn87
Hello!
I bought used savage flux xl roller with losi lst xxl shocks(plastic ones) and i-rc lst shock conversion kit..
The deal is that 3 caps are broken,one shaft and shaft end is busted, probably need new cartridges with seals to prevent leaking...
So aluminium caps,shaft etc will cost me around the same as new hpi bigbore shocks(plastic)..
My question is are lst xxl shock worth repairing or should i ditch them in favour of bigbores?
How they compare those shocks in bashing etc..?
Anyone know where to get only shaft end for lst xxl shocks..
I've never ran big bores, so I can't compare the two. But IRC's LST shocks take alot of abuse. Now clearly you don't have IRC shocks because yours have plastic bodies. IRC does sell alot of upgrades for LST shocks as well, including a kit to upgrade them to 8mm shafts. That should makes those shocks darn near bulletproof. As far as your rod ends you need, it depends on what size shaft you're using. IRC sells 4mm and 8mm rod ends.
