xtremsavage
OG HPISF MEMBER!!!!!
- Location
- Jacksonville, Fl
I tried searching the forum but couldn't find any good results, but does anybody know how to check and see if the front motor bearing is leaking? Is there some sort of test that I can do to check it. Also, what's the best method to replace it and should both (inner and outer) be replaced or just the outer rubber sealed one? Also, what would be a better replacement over the original? Went to finish putting the truck back together the other day and noticed a puddle of red fluid (same color as the fuel I use) sitting under the truck around the motor area. Not quite sure if it came from the motor or not yet, gonna reclean around the motor and see if that's where it's coming from. Any help on this would be great.
