Just wondering
To make up for being stupid I grabbed my savy to get you dimensions. I have the X style box mind you.
6.9mm wide 3.3mm front to back and 3.5mm deep with no modification.
According to that it may not fit.
6.9mm wide 3.3mm front to back and 3.5mm deep with no modification.According to that it may not fit.
I don't mean to be rude parkermarsh, but if your battery compartment is that size, you ain't gona get an awful lot in there ! I think you mean 60.9 x 30.3 x 30.5mm or (6.9cm x 3.3cm x 3.5cm).
So what's the verdict. Does anyone use this. Personally I don't like anything under 2200mah, not enough juice. Peace.
P.S. Thanks to the person who corrected my spelling(text subject).
I just got some dimensions to compare.
HPI 1200mah pack for Savage,
L = 50MM
W = 31MM
H = 30MM
HPI 3000mah pack for 5B,
L = 66MM
W = 46MM
Thanks to all for their help with this problem. I just want to make sure it will fit before I buy it. Peace.
So much for making up being stupid! I had a crying kid and my mother yelling at me trying to get the house ready for a party tonight. I know, excuses, excuses! You guys know what I ment.
L = 50MM
W = 31MM
H = 30MM
L = 66MM
W = 46MM
You got the dimensions, measure your box. You may be able to pull it off using a RX battery relocater.
Cool, I'm waiting for the New Year to get the Innovated ext lcg tvps, I think this will let me fit a mid tank mod plus the 5B hump pack. Parker here are some rep points. Thanks again. Peace.
No problem man. Glad I could be some help. I will look into the battery boxes a little further when it isn't so busy around here. I think the ext TVP's will open alot of doors for creativity and room.
I have been wanting to be able to use some higher apm hur rated batterys for mine too, what I have been thinking is maybe one of those larger packs could be taken apart and put back together to fit if one or 2 of the cells were in that little area in the front of the radio box, just run a pair of longer wires to them. Just don't know what if any will fit up front.
Stealth attack had a hump pack that was too big after a midtank mod so he just ziptied it to the front undercarriage beside the drive shaft. You have to make sure its tight so it don't slide over to the drive shaft but it worked good for him.
Cool, thanks all. I should be able to start this mod in a month or two.
Parker I tried to send you some rep points for all the research you've done. But since I hit you with some rep points last time, it won't let me. Peace.
