Jammin pipes? Help!!!!!
xsavage3148
Anyone running one? What did you do to get the header to fit right? Just flip it? I have extended tvps' so that not a problem.
To my knowledge the jammin pipes are all inline. So the pressure nipple is on the side, or the exhaust stinger is in the way. I have a jp3 that I'm going to try to run but I'm afraid I will bash the pressure nipple into my chassis.
it will work i have seen people doing it but i didnt know if there was a trick. some people put a new nipple on it. if you turn the pipe the pressure nipple is on the inside but its not close enough to my tvp to bash in. i just didnt know if the head would be ok flipped over.
I replied in a pm.. IMO you should have gotta a new header.. would have solved all problems and.. NOW you have even crazier problems..
