I'm having a little trouble
Punk3460
Canada
okay heres my problem, when i start up my rc car i can get it running but it quits if i run the throttle even a little ive tried making it more lean but now it wont start at all, a little help?
open the filter and apply full brake, the hole in the carb should be around .1mm
close the big screw till close then open it 2.5 turn
adjust ur remote throttle tab which change the engine rev via the servo
Where did you come up with that? I don't even see where he posted a problem.....:duh:
