humppack install
609savage
dirty jerzey
well i recently got the 1500 mah hump-pack form onlybatterypacks.com and i installed it on th front shock tower like i was told on the instruction manual for the h/pack ...but i notice when i put it on there,it is nearly impossible to put it on the small area flush...the only way is to put it catty corner to the tower...and it is hard to access the pins if i wanted to move my body pin tower...i thought i heard of a mod where you can take a battery box and trim it and the 5 cell would fit in there perfect and mounts with no problems..it will sit flush.......please help
I just attached the Rush battery box straight to the clips that hold the body posts on. Than ran a small screw through the inside of the box into the shock tower and its sold as a rock.
no I'm running stock tank......only different mod is the savy xl tvp's.....
Pics of the batt. pack and truck set-up would definately help out. If we see the pics, we would be able to help you out better with a solution.
that is a cool idea GO TO
I have ran 4 of those in mine before
Soldered parallel by the looks of it. Great idea on the 5 cell pack.
609 - Is that a 5 X AA or 5 X sub-C pack?
