DOOBEEWHA
HPISF languist expert
- Petaluma,Ca,
thankx
Thanks DS. Thats great information, bud.
What is it about those who can't even say "Thanks for the tips and links"??HPI Savage25, I can tell you how I mounted the wing on my Savage race truck.
First you will need some parts from Amain Hobbies because they are the only place I can find that stocks Kyosho parts. Here are the pages for the needed parts.
Wing stays, http://www.amainhobbies.com/product_info.php/cPath/1_25_134/products_id/3907
Wing, http://www.amainhobbies.com/product_info.php/cPath/1_25_134/products_id/3874
If you click on the Kyosho MP7.5 in the upper header it will take you to the main Inferno parts page. The first wing, blue, is at the bottom of page 1 and all the rest are on page 2.
Ok, after you get the parts you need to cut the forward most part of the wing stays off. This is what the look like:
This is where you need to cut off:
Make a cut that is back from flush with the bottom through bolt holes. Here is a side pic close up to show you how to cut each side of the wing stay.
Use two of the short bolts used to hold the Savage X diff cover in place, Z634. Screw the Z634's into the holes that you normally put body clips into to set the body post height.
Your done, Savage wing made easy. This is what it looks like when your done.
As for shocks. I used Integy MSR7 Hellfire shocks for my Savage. The are super beefy and give the truck a really mean stance.
Your Savage looks good, get the wing on it and it will look that much meaner..
