HPI F4.6/bearing
Crash
Chicago
hey guys
what do ya think of this bearing by looking at it
looks to be leaking or do you think its just junk built up behind fly wheel?
Looks like it could be leaking a little excessive (Yellow tord bottom) and a lot of junk build up. The front bearing is not what seals the engine though. It is actually sealed by the tolerance between the nose of Crankcase and the front of the crank just in front of the air/fuel inlet.
When you pulled it out was the motor plate filthy in a line pattern just below the Flywheel?
idk
its freds engine
looks clean everywhere else on engine though
evan rite below bearing. wierd
It may just be junk there. You can either replace it or have him run it and watch it and he can replace it.
The front bearing will and can seep a little bit which is just fine. New high end mills will do the same.
It is possible to take out the tolerance seal on the front of the motor. This is done by dust intake or junk in fuel or a bad bearing with to much slop making crank rub on the crankcase.
pretty handsome lookin' mill you got there crash.....i'm thinkin' replace before it goes back in to my savage. if someone can hit me up w/a part # i will have it standing by............frddyj:duh:
If you want to send it here and Ill throw it in
