HPI Engine Stopper
Hi, can anyone confirm if this can be fitted & work still if you have a fuel tank guard fitted also please?
Many Thanks
Can you post the guard you are using? I know when I had my new era kit with ofna tank I couldn't use the engine stop because the kit mounted just below the tank (where the engine stop mounts). If your guard does as well, I'm guessing at the least it will need modification.
Here’s a close up of my tank guard, thanks.
It looks like the bracket for the guard, to the left of the tank is likely going to be in the way.
Here is a picture from HPI's site. Not a great view though.
Clearer/closer picture then I could find thanks! ??
Yes it will foul bottom left of my guard, but looking at it I can cut away this section & still use original fixings for guard! ??
Think I found the only new one left in England, the only other one was your side of pond & then seller told me someone brought all the last six he had in stock at time! ??
