- Dekalb, IL 60115
- Thread starter
- #31
Yeah, the only thing I have left is fuel. I'll probably just get some new fuel and try it with the tank that's in it.
Some engine modders offer break in service with and without modding your engine. I've never used it but in light of the op trouble. Just offering another option / opinion.Not sure what your asking.
I see. I've broken in 20+ engines and have never had the issues I'm currently having.Some engine modders offer break in service with and without modding your engine. I've never used it but in light of the op trouble. Just offering another option / opinion.
Doesn't sound like you did anything wrong, not that I'm qualified, but at some point the frustration experience has a toll. Wish I knew the answer I've never owned an LRP and just recently got spanked by one with my picco x. No excuses four runs and it owned all of em. Hope you get it sorted
What percent fuel you using?Finally found time to run more fuel through the 30... what an abysmal day. To recap, engine has around 1500cc's through it, new HPI savage X tank, new fuel lines, sealed engine.
Starting was a pain. Once it finally fired up, it was so pig rich from previously running ok that it couldn't hardly move. I had to lean the HSN almost a full turn after trying to get it to warm up. Then it seemed ok, but still had a rich bog at WOT. Tank 1 today was a pain. Lots of stalling, weird exhaust note, bad performance... and it just got worse. By the time I finished off 500cc's of fuel, I had reset the engine back to factory 3 times and had to richen both the LSN/HSN at least one full turn due to seeing temps north of 300F. I ended up with it very rich and running like crap, then the tank was almost empty and it stalled, then I threw it in my car and came home before I set fire to it.
I'm ditching the HPI tank... not sure what I'm going to use in it's place, but probably an OFNA 125cc tank I found that is close to the shape of the old OFNA 125cc tank I had. I have a feeling ti is either the damn tank, or my fuel. THe fuel is fairly new, but the LHS I got it at doesn't seem to have a high throughput of nitro rigs and/or fuel. Luckilly, I have 2 gallons of it... lol. Probably goign to just bite the bullet and order 4 gallons of byrons 2500 that I've used for years from amain for $160.
I knew I should have just stayed home...
Was running 25% odonnels, now running 25% byrons.What percent fuel you using?
Ive ran the stock tank on my xl and 25 forever.....never had a problem with them except for the normal "half tank lean"....that can be fixed by simply drilling a hole at the bottom and installing a outlet... Sounds to me like you're getting air.....or either your fuel is bad..
What tank did you buy @olds97_lss ? Now that I'm getting my savage running I'm experiencing half tank lean and was about to research what I could do to counteract it.Yeah, I don't know. I have had 3 or 4 savages over the years and hated how inconsistent the tune was with the stock tanks. So I always ended up just throwing a 125cc buggy tank on them which seems to solve 99% of my tuning issues.
Where do you drill the hole and install an outlet?Ive ran the stock tank on my xl and 25 forever.....never had a problem with them except for the normal "half tank lean"....that can be fixed by simply drilling a hole at the bottom and installing a outlet... Sounds to me like you're getting air.....or either your fuel is bad..
The one in the photo is the OFNA #19076.What tank did you buy @olds97_lss ? Now that I'm getting my savage running I'm experiencing half tank lean and was about to research what I could do to counteract it.
What is your recomended fuel and plug to use on an lrp zr30x?I still don't think drilling a hole and bypassing the stone filter is a good idea. I use the troublesome extra loop method, and while it sets my CDO (just like OCD except it's alphabetically correct) On fire, it helps. Doing an actual mid-tank might help, but I haven't. So I can't say.
Got my OFNA tank in yesterday. Can you post a better picture of how you mounted yours @olds97_lss? I have a few ideas floating around in my head, but never hurts to have a good starting point from someone who has already done it.
Very nice! Looks clean. I been goin thru it with this lrp zr30x motor. I just cant seem to get it tuned.. any suggestions?Not sure what else you need:
For the front mount, I used a 4 or 5mm bolt that was long and only had threads on half for the throttle arm to pivot on. I drilled out the throttle pivot mount so the bolt would go through entirely without splitting it. Then I drilled on the front hole on the tank to be large enough for the bolt and fuel tubing around the bolt for shock absorption. a bolt, washer, fuel tubing, and locknut. For the rear, I took a piece of 5/16 round bar and made an L bracket, used a 3mm bolt/nut/wash through the rear flange of the tank for shock absorption again and used a previously made hole through the TVP to tie the L bar to the chassis.
Well I'm running the stock tank its a 3 speed xl and I'm running byrons 30% and 16% caster with an os8 plug. Yesterday i couldnt even get it to accelerate with out it loading up and dieying let alone get to idle without the glow ignitor. Now I'm getting it to run but its got no speed just alot of low end torque. No matter how much i richen or lean it i cant seem to find the sweet spot. Once i start leaning it then it bogs down i fatn it up and i get alittle speed but not much. Just seems to me its definately a tuning issue and ive read on other forums the lrp or manuel on this motor stock setting where way off but i cant seem to find anyone with sum helpful tuning settings for this motor. Have you or do you know anyone that has or had the lrp zr30x motor?Mine ran like crap with the stock tank and odonnel fuel. Now that I'm using the OFNA tank and byrons fuel, it's a night and day difference as far as stable is concerned.
How much fuel is through your engine? What fuel are you using (brand, nitro %/, oil %)? What tank, tires and gearing? 3 speed or 2 speed?
