I'm planning on mounting it as close to the bulkhead as possible. And I'm probably going to cut off the exhaust tips a little bitTry not to land on the rear bumper, or you're going to destroy that exhaust very quickly. It looks cool, but the location is awful.
Hopefully you have better luck than most. 🙂
With enough tools anything is possible. Ill look into making a buffer rig.that won't help. if u land hard enough, the bumper will easily hit the bulkhead. I wonder if it's possible to put alum bumper supports on it.
Thats what i was thinking. Or if i could make some supports out of something like carbon fibre that would go from the shock tower to the bumper possible with some type of absorbtion system in between.this is a front bumper, but it's the same general design. see those two "arms" in the back? that's what I think u should try to find in alum. not the whole bumper, just the arms![]()
Would the flywheel from my old .25 work or is it a compleetely new setuphttp://www.rcplanet.com/HPI_Heavy_Duty_Ceramic_Slipper_Clutch_Pad_2pcs_p/hpi107454.htm
http://www.rcplanet.com/HPI_3_Pc_Clutch_Set_Savage_p/hpi87153.htm
flywheel and collet along with carbon shoes, but I would use alloy shoes for the clutch Like these VVVVVV
http://www.rcplanet.com/HPI_Aluminum_Clutch_Shoe_Set_3_Piece_p/hpi87196.htm
Its a 3 pinif is a 3 pin it should work fine far as I know
Man me to its been way too long since ive been able to do stuff like thisyea, it'll work. looks nice! glad to see it comin' together
Rgr ill need to get my hands on some soon then.Traxxas fuel is really only good for traxxas engines.
I run sidewinder race blend.
