Fioroni NOOOB need advise
JoeGuam
Virginia
Fioroni experts, QA and advise the correct installation. Not a good explainer with words so I figure a video is better.
not sure but I'm sure bank will know! looks like a nice clutch, I need to replace the one on my new project but the funds arnt there right now!
Good luck
ahh ok you have a different one then I do. I have the twin turbo its a 4 shoe. I don't think it will matter so much how you put it on. Id do twin spring out.
On that air filter they don't like piccos !!!!! you need to take and cut the bottom of the tube so the rib will engage the carb correctly or you WILL flig it off ...
^^^ take this advice to the bank (no pun intended)
Yah I had to do the video as it was better to understand. LOL I installed all three springs. I willl work with the Air filter in the mean time. The only other one I have is the filter that came with the 5.9. What air filter are you using for yours? What is a good one to use? Thanks again.
Is it just the tube, or the whole Motor Saver? I guess it will be another week till I get the best Filter Picco combo. I have to order online, unless a LHS here in Japan has a recommended filter <-- Two hour train ride to Tokyo.. Hint Hint ERCM Picco users advise please.
