F5.9 with pullstart.
NapiersTowing88
Bought two brand new HPI F5.9 Engines with pullstart. They hard to pull, I finally got one to start and run for a break in tank. The other one is harder to pull and the pull string gets locked up when pulled out, I have to rotate the flywheel by hand to get the rope to go back in. Any help? Thanks, they both for a twin build. 20250131_103858.webp
Bought two brand new HPI F5.9 Engines with pullstart. They hard to pull, I finally got one to start and run for a break in tank. The other one is harder to pull and the pull string gets locked up when pulled out, I have to rotate the flywheel by hand to get the rope to go back in. Any help? Thanks, they both for a twin build. View attachment 12050
looks good that bro n ye probs take dodgey 1 off n clean it up n find the prob wi recoil
Ha ha my bad that’s a nice build that n ment to say pretty much same as wot JAM 1 said take apart clean n inspect
Warming the cooling heads with a heat gun (moderate heat) also helps. If you loosen the glow plug make sure you tighten it after the beast starts to roar...
Beautiful make by the way!
