nitrobasher
I am new to this forum so don't hate me if this has been done before. After reading the thread by maximusraylius on modding stock shocks, decided to experiment a little. If you look on the stock shocks there is a plastic piece above the springs that is removable (not sure what it is called).
So what I did was remove these from the front shocks.
And put them on the rear shocks.
So what this did was lower the front end and raise the rear end.
This allowed the truck to dive into corners and turn on a dime. You could also remove the pieces from the front shocks and leave the one on the rear, this will be a little less agressive. I know this is not a permanent mod, but it does allow you to change the ride height and see how it handles different. When I permanently mod my shocks with the fuel tubing I will put a longer piece of tubing in my front shocks than in the rear.
The thread I mentioned above
https://www.hpisavageforum.com/forums/showthread.php?t=11272
Thank you guys for all the AWESOME information!!!!!!!!!!
Chris
Chris
