MikeK1981
ChondroManiac
- Humboldt, CA
Sounds lean to me too, Idle hangs too high after WOT and doesn't seem to settle down as low as it should during idle. Have you read Purenitro's tuning guide? I definitely learned to read my engine better from that guide, just by the sounds alone. I would richen it on the high end and then lean the low if needed agter that. After you richen the HSN and adjust your LSN for good response off the line you'll need to adjust your idle too. I don't see enough smoke in most of the the vid.
