educate me on starters
New Cumberland, Pa
I have a .21 with a pull start. My arm is tired Lol plus the 1 way took a crap so I figured while it's apart for that, I'd like to put on an electric type start. I don't want the stock roto start though. Is there a setup out there that has the bit you can chuck up in a drill that will work on a savage? I know the MGTs have a hex shaft with a balled hex on the end and it's just used in a standard drill. Thats basicly what I'm after. But every back plate I see for the savage has thta dogbone style fitting.
welcome to the forum bud.
as far as your question, you can put a roto start shaft into your drill chuck.
you can order just the starting shaft.
I would suggest if using a drill make sure it's reversible of course and it has a clutch on it and to set clutch on a kinda weak setting so if engine floods it doesn't wipe out your new starter,just my 2 cents,Dave
Thanks guys. I didn't think the rotostart shaft would work in the drill because it looks round in the pics I seen.
Dave, i have a craftsman 19.2 cordless with both reverse and clutch. Thanks for the tip.
And other than tower does anyone know a good source for those bearings? tower was the cheapest I found.
check nitronutzz , I don't know if he can get it but, worth a try. mention I referred you for 10% off
heres a pic of a members savage!! View attachment 804 i don't know the owner of this savage but i saw the pic in the album and thought it was cool to see a easystart system on a savage!!
You can use a roto start shaft in a drill. its only round 1/3 of the way,after that its a cut like screw tip bit. 6 sided cut.
Mon is right. I've had to use my drill once when my battery died for my roto starter. You might wanna try looking at the tiger drive unit. I believe the shaft needs a drill to start it. Not 100% sure on that one though.
Yes- I went that route also(Tigerdrive) That shaft is also 6 sided and has a ball at end unlike Rotostart that has that dog bone tip.Tigerdrive shaft is shorter though and likes to strip out easy because of the ball end so what I did was to cut the very end of my Rotostart shaft which is longer and made sure I had a strait shot at it and it worked fine for me that way.But I eventually went to pull start which is better IMO,Dave. :beer:
Thanks for the info guys! I just ordered up a tiger drive.
In the description it states it includes the 1way bearing, and that is sweet cause the one in the pull start just went out on me.
