Diff spur gear spinning, but spider gears arent & Metal vs Non-Metal Diff Gaskets
cyr4x
I just got a used savage gtxl-1 on the 13th, and it was working fine, tilll i set the punch to 9. Shortly after, the car lost power but i could see that the driveshafts were spinning. I took out the diff, opened it up, and saw that when i spun the outdrive, the spider gears weren't spinning. How do i fix this? Also if anyone has one dogbone or 2 cvd's for the wheels in the LA area, tell me, I need one.
Until you put a center diff in it, the front and rear diffs won't last long, I also recommend using at least 100k cst oil on the diffs. On mine, I'm using 200k front and back, 500k center.
Does yours do standing backflips?
It does, in this video I did some rolling backflips, which is even harder, and I'm doing it with 80c LiPo's and without a wheelie bar
you make me a proud to own a savage xl flux, and thanks for the suggestion. I was originally going to do 10k as they do in the arrma6s
but also i wont be running a center diff i don't have the money rn, so what should i run?
The Savage platform has potential, but not in stock form. If you want to run your savage like I do in this video, those are just some of the must-do mods:
º Machined bulletproof diffs HPI- #102692
º Install a center diff kit of your liking
º Change the diff fluids for thicker ones
º Buy shim washers to do a proper diff shimming
º Savage XL 17mm Hex Hub Conversion Set HPI- #160141
If you don't have money atm, adjusting the slipper clutch is your only option for now...
Also I'm not running 8s, I'm running 6s stock electronics. Would 200k work good or should I go with something else?
