No mechanical brakes. They're 40c rated, so they should hold up OK. HK was all out of 5k 6s packs when I was placing orders.
One of the center dogbones (rear, I think) was replaced with a CVD on the roller. Since it's too short for the DB17, I need a new cup joint on the bulkhead side. Is this the right one? http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFYK9&P=7
The part number is wrong in the savage x exploded diagram.
They're rated for 2c charge rate. They should have no problem at all with the occasional bit of braking feedback.Can they take the feed back of braking? I was told not to go with the MMM under 5K with ESC breaking. I went mechanical and don't worry about it anyways. But may be worth researching b4 you puff them. The 40C rating is just the go side, not the stop..
Do you know the part number I should be using? And why the heck are they called "heavy duty" if they wear out faster than the standard ones?don't use the HD cups they wear out super fast...
Thanks. I'll give it a shot.
Kershaw is going to make me a motor mount for $40. The bad news is that it's going to take about 3 weeks. It'll be worth it if it works out in the end.
I did the same thing. I think I paid $8.50 shipped for a set of four. Got all the other odds and ends from ebay too. Those guys that part out the new kits are quite a bit cheaper than tower.
it will get pounded by the tower itself as it bends and flexes.
Either way, the battery wires won't quite reach.
Never painted a RC body before. Do you cut then paint, or paint then cut?
