dare i say tuning help (if i could drive it)
keane
don't be hard with me.... i know I'm gonna be a pain BUT i ran a few tanks through my X46 did not drive it really tho few weeks ago.
Now the weather is better i want to take it for a spin BUT how can i try and tune it when it wont keep running, i mean i can start it fine (its at factory settings) but as soon as i touch the throttle it will just stall, some times it would run for about 20 30 sec then just stall, i have read the tuning guides but i just cant seem to keep it running when i give it a touch of throttle, i have adjusted the idle but still not much difference, anyone point me to a fools guide for this TA...
At one point i think i overdid the idle cos soon as i started it i had to hang on to it big time or else it was gonna fly away real fast ( woke me up i,ll tell ya) I mean REAL FAST lol...
BE Nice..
Lean each needle (HSN & LSN) 3/4's of a turn (Clockwise). Start there you may also want to turn the idle up a tad as well which will keep the Idle RPM higher and will stay running better. Go give that a shot and come back and post the results.
Do you have a temp gun if so make sure the temps get up to around 200*F or it will not stay running.
cheers for the fast response i will have a go and get back later in the week now, busy working all week (wrong shift).
ya please never be afraid to ask questions here as thats what this forum is all about getting the help you need so you get the absolute most out of this addictive hobby!!
did you mean tune down idle, cause he says it is already trying to run away?
i tweaked with the idle, i know it opens the carb up but it never made much difference , i prob was doing it wrong way or not enough, I'm gonna take the filter off and check for the mm open, also i think i moved the trim on the controller alot and thats what made it try to fly like a bat, do you think i should set the trim up so its all the way down, its a std hpi hand controller so it hasn't got much in the way of marks on the trim, least i would know exactly where to put the trim, how do u guys do yours..?
well on mine which is the same stock radio, for starting i usually have the trim a bit past center "line on knob straight up" this speeds up the idle and makes it easier to start once its started and run for a few secs i turn it back to center "or till it makes no difference how far to the left you turn it" hope this helps!!!!!
