Carb Orientation
there is a bolt on the side lossen it / remove it gently remove carb and reinstall the way you need it...put associated "green slime" lube on the o-ring on the carb before you reinstall to help you keep a better seal at the carb base...works good on the hs/ls needles too--just lite coat not heavy!!!
I was almost embarrassed to ask, but since it was new I just wanted to be absolutely sure and to make sure I didn't order the wrong one. Thanks jcam
