Ok...i have run the required amount of tanks with the required amount of throttle as both the manual and the forums are stating. I started tuning last night with the HSN and went about 2 to 3 1/8th turns. The truck was screaming..wheelies...everything...I had a blast. Then it stalled and wouldn't start back up. I thought maybe it was my glo plug ignitor being dead so I called it a day. Today I picked back up and I can't keep the truck running very long before stalling. I did some research and I found some suggestions for trouble shooting but wanted to also get other opinions since the truck is so new.
Here are the symptoms:
Fuel (gooey muck) spraying out of the pipe when running and dripping at idle.
As soon I engage some throttle it stalls. The truck does start no problem but at idle it conks out. It conks sooner every time.
Here are my possible solutions that I found.
Lean it out... ok but how? Turn the HSN more clockwise when the trucks off?
Install new glo plug. I did that. I'm running an OS A-5 I have some McCoys MC-8s on the way. Is this not a good plug for now????
This is about my 9th tank and I'm assuming its getting to much fuel as its coming out the exhaust and pumping out of the engine when I take the plug out and crank the motor. But not always thats why I'm not 100 percent its flooding. I'm still to new at this
Any thoughts???
Also..what is a good hump pak to purchase. I got a 1400 mah from the LHS and it doesn't stay charged very long.
I appreciate the assitance in advanced
Any thoughts???
