Some of you know, my first-out with the RSC, i grenaded a carrier on the front. The screws that come with the kit are short (so they sit flush when installed) and even if you loctite, they work themselves loose.
In this pic, the stock screw is installed in the top the bottom screw actually came loose & ripped the threads out of the bottom
In this pic, i compare the screws that come with the kit (short) with the screws i used as replacements.
Loctite & Install (notice the screw extends beyond the carrier)
I also recommend that you check these screws before each run to make sure they dint work themselves loose 😛eace:
