Lexpert81
- Location
- Brookfield WI
What are the pros and cons of a metal sg i have had a issue melting plastic ones and i need to know if a metal one is a good fix
you need to make sure your mesh is good with a composite spur or steel gear. Steel is gonna be a bit more forgiving to a bad mesh, or tweaked motor plate.
i upgraded to steel from composite just to try it out. i love it. but then again, i never had a problem with composite.
composite spur gear being a 'weak point' is a myth, a bud of mine grenaded his tranny while running a composite spur & no damage to the spur (caz he had it meshed right). Tranny? Gone.
Adjusted properly, the 'weak point' on your tranny is your slipper clutch; that is what its designed to do.
Whatever you choose, make a habit to inspect your mill plate, mill mount, motor mount screws & above all else--> Mesh 😛eace:
yea the last one melted the center so you think i have to only back the nut off a 1/4 turn.
Do you think this happend from doing some big hill climbing it stopped moving after a few runs up the hill it was great untill then
When Bank says hd spurs he means metal right ?
