new pipe for lrp
Dreadnaught
Diesel Powered!
Pinckney Michigan
i have a Buku, and for me, its too much. I'm looking for a good low/ mid pipe. I am looking at the Ofna 053, or the Dynamite 053, whichever. Anyone run this? Pro's/con's?
thanks guys.
Kyle.
The 086 doesn't seem to affect the low end but does improve the mid to top end.
The OFNA is nice because you can add a exhaust deflector to bit but the Dynamite one is nice because of the Hard Anodized coating which makes for easier cleaning and longer lasting finish.
i was lookin at the hard annodized finish. i was also thinking aboutmaking it a left exit. swappin the tvp's around or something. cus i think that it being a left handed pipe with the pressure fitting on the side instead of the pipe somehow affects it. maybe purenitro, or someone like with his knowledge will chime in.
i had the 086 on my lrp (keep in mind its modded) at the bash with bank, freddy, vis, and jud last sat. didnt seem to impresive to me on it, i slapped my macs on and it really seemed to come right to life.
May I ask why you say the Buku is to much for you? Is it to much maintenance or are you speaking of to much power. If it's to much power the mac's or 086 will more than likely over do the Buku.
I run the 086 on mine and it can pull 2nd gear wheelies at 30mph 19/47 on demand.. standard length mind you don't think it could in the ext truck.
Id go for the 086. I run dirt bonz on mine too. That mill stock likes to rev. 086 will let it. But what do you like to do with the truck? If you never open it up a top pipe is not needed ya know.. it will make all the power you need on bottom /mid with the top pipe
i run it in about 5 acres, short grass. occasionally i get it out at my buddies house and we have about 1/2 acre but there is a dirt road with some sweet embankments we play on too.
its usually wide open, but i like to have the power to rip wheelies on demand.
With that much room to play, I too would go with the 086. It is a top end pipe and a good match to the LRP which won't lack any bottom end with it, you can always go down a tooth or two and still have good speen due to the rpm the LRP pulls. The 053 is a good pipe for the less powerful engines due to the fact it is a bottom end pipe, it would hinder your LRP's top end and probably cause over heating issues on the long pulls. If noise is not an issue then a 1120 Macs pipe is your best bet, excellent power band from bottom to top . It is loud and can be heard 1/2 mile away lol. Hope this helps bud.
Do you still have the buku and do you want to sell it
waitin on payment
086 dred you will like it.. if not Ill buy it off you. I am looking for a 3rd..
i'll keep that in mind
that macs would get a rise out of my neighbors. their daughters already hate the savvy. so that would probably cause a complaint.
