These are the next servos I plan on getting when I need to replace my current ones.
For throttle/brake
Link:
http://www.hitecrcd.com/servos/show?name=HS-7940TH
Hitec's fastest standard size servo the "Ultra Speed" HS-7940TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7940TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7040TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7940TH has been designed for applications where speed and response is demanded. Perfect for High Performance Nitro and Electric Helicopters, Aircraft, Cars, and Trucks. Featuring a blistering transit time of .07sec but still maintaining a respectable 183 in/oz of torque at 6.0 volts.
Due June 2009
Detailed Specifications
Motor Type: Coreless
Bearing Type: Dual BB
Speed: 0.07 / 0.06 sec @ 60 deg.
English Metric
Torque: 181 / 222 oz./in. (6.0v/7.4v)
Detailed Feature Descriptions
G2 Digital Circuit
Titanium Gear Train (MK first gear)
Ultra Performance Coreless Motor
Heatsink Case
(8) O-Rings for Water/Dust/Fuel protection
Dual Ball Bearing Supported Output Shaft
Programable Features Include:
Dead Band Width
Direction of Rotation
Speed of Rotation (slower)
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
Resolution* (default is high resolution)
Overload Protection* (default is off)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers
For steering
Link:
http://www.hitecrcd.com/servos/show?name=HS-7950TH
Hitec's strongest servo period, the "Ultra Torque" HS-7950TH is designed to operate on a two cell LiPo Pack. Featuring our high resolution "G2" second generation programmable digital circuit and our indestructible Titanium gears, The HS-7950TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7050TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7950TG has been designed for the most demanding hobby applications including the largest aircraft and monster trucks. Featuring a titanic 403oz./in. of torque at 6.0 volts, while still maintaining a respectable 0.15 second transit time
Due June 2009
Speed: 0.15 / 0.13 sec @ 60 deg.
English Metric
Torque: 403 / 486 oz./in. (6.0v/7.4v)
G2 Digital Circuit
Heatsink Case
Dead Band Width
End Points
Neutral Points
Fail Safe On/Off
Fail Safe Point
