Running problem
bigbazz08
perth western australia
Hoping someone can help i was running my truck 4.6 ss x at wot it sounds like its popping not a high pitch more of A low pitch popping it takes of well mid range good can any one give me suggestions on what to look 4 to start of with thanx
did check 4 air leaks unable to find any,didnt have temp gun with me at time,but it usally run about 140-160 degrees celcius,also gave the carby a bit of a clean as well as the air filter,as i havnt run it since don't know if fixed problem hopefully will run this weekend
if i were to start with the factory setting hsn would it be where the line is on the brass tube,also a while back i didnt realise the fuel tank cap wasnt closed properly and the temp sky rocketed around 180-200c i hope it hasn't done any long term damage
The only brass tube is the hsn correct but the top has a black cap so how do i teel if it is flush like your saying sorry 4 asking such a noob question give me a 1 to 1 car any day
bigbazz, on your engine, the factory setting on your hsn is the bottom of that black cap is even with the line on the tube.
