Diff case screws
mekios
Athens, Greece
So after having a beautifull conversation at the I'm about that i am bringing it up for extra huss-huss here in the forum, so anyone having the same prob can find out a solution (out of the many suggested).
The problem is i can't get those screws out! I got perfect fit phillips screwdriver, but only 1 or 2 screws can come out. The rest are loctited like hell.
What do you guys suggest to break the loctite?
So after having a beatifull conversation at the I'm about that i am bringing it up for extra huss-huss here in the forum, so anyone having the same prob can find out a solution (out of the many suggested).
1. what does this mean "...at the I'm about that i am bringing it up for extra huss-huss here in the forum"
2.apply some heat to whatever your trying to unscrew, heat will soften up the loctite.
I would go with a heating method. that green loctite (or whatever color they use) is tough stuff. Getting those screws out is difficult and you can easily strip the heads out. I have drilled a screw out successfully on one diff and completely trashed another diff doing the same thing.
Many thanks guys!
I bought a dremel versatip butane torch and it worked like charm! 30-40 secs of heating on each screw and they came out like a young child screwed them in!
