bubbles in fuel lines
dirtbasher
hi guys,
started it today n noticed bubbles in the tank and fuel line. i'm also using fuel filter. took out the fuel filter n connect direct, stil hav bubbles. i chk all fuel lines seems 2 b ok. anybody know why?
mine has em until i fire it up, then the pressure blasts the fuel through
you notice the bubble just when the mill is off or when she's running too?
you shouldnt have any bubbles while the truck is running what-so-ever.
if you do, then you have an airleak somewhere along the line.
Fuel tank cracked
Fuel line has a split
Backplate is loose/not sealed correctly
Airleak at carb neck or inlet
Carb O-rings are damaged
Main bearings at crankcase
some ideas of what you can look at to remedy this issue.
good luck
Fuel tank cracked
good luck
thx SwampDawg, wil chk on that...
