OS 30VG mill
dirtbasher
hi,
wat do u guys think of OS 30VG 1.80hp@26,500 rpm, max rev 35,500rpm?
dyno test by Xtreme Rc Car.
The OS is a great trust worthy mill that will last and hold a great tune. Its also a pretty torquy mill. However, the Picco and some others will out run it in speed and also overpower it for a little cheaper.
i think i'm goin for the modded Picco P3 .28. modified by AB Mods.
Larsenracing,wat is a good tuned pipe to go wit the mod Picco P3?
you know it. dynamite 086 is basically the same pipe too
Correct other than the headers and the Dyn is Hardcoated. The header on the Dyn will not fit on a standard length Truck. Also, if you use a exhaust deflector it will not go on the Dyn because the stinger is supported. I run 2 of the Dyn 086 pipes.
