racerb
- Location
- Kamloops B.C. Canada
Hey all,well I am just at a loss, I picked up a used savage, that started when I bought it... It was in serious need of tunning and a couple little other clutch issues,when I bought it which is why I got it for a decent price, I am not new to rc but am new to nitro.... I cannot for the life of me get the truck to start, I have done all the check that need to be done, but it doesn't seem to be getting fuel into the head..... If I prime it by sticking my finger over the exhaust and pulling on the pullstart it eventually gets fuel but the fuel does not spray out but will run out of the line..... I am about 95% sure my tank is all good.. the only thing I have not done is immerse it in water.... I can blow into the exhaust line and get fuel spray good, so this is how I tried to prime it.... still nothing, I put in brand new plug, all batteries (igniter etc) fully charged..... What I have also done is return all needles back to flush in an attempt to start fresh, and tune on my own.....
here is one question thou.....is it maybe not getting all the pressure it needs because the pull start is maybe not working 100%?? I switched to rotor start and it maybe seems like it possibly missing a little... maybe not full stroke?? (I am just grasping at anything here guy's) not enough pressure squirting fuel in???? could this also maybe a result in the one way bearing not working 100%
well I have wanted one of these since they came out but could not afford one, but now I am thinking I maybe should just give up... but I reall don't want to... so help me please!!!!
P.S sorry all it is a K4.6 motor, just in case that matters to anyone suggesting...........
oh and another quickie as well, I had to re-do clutch, there in a bearing on the outer and inner of the c.b. but when I got to tighten everything on I can still see the shoes between the flywheel and bottom of clutch bell.... there is no shims inbetween the nut holding the flywheel on and the inner bearing on the C.B. ....... so is it possibly something underneath the fly that is messed... when I spin the C.B. it spims nice and free, I also replace with alluminum cluth shoes and there is some things that look like set screws that go into them... is this for a differnt set-up/ truck or what do I do with them..... oh the biggest issue with the cluth bell sticking so far out is that the edge of it can rub on the brake disks... I was told something about and old 5/10 bearing and using it as a shim or something rather than the brass bushing.... does this go under the flywheel... or does anyone have a clue what I am talking about??
thanx to anyone that can maje any sense out of any of this... I am deperate!!!!
