should the pull start be fairly rough to pull? not just one smooth movement
no fule filter and it has clear lines and i don't see anything in the lines . blew in the exhaust line and it easily flowed through but when its hooked up its a lot harder.
Opps I messed up on that prime procedure-sorry-pull pressure line off at exhaust not at tank-duh.[/QUOTE
could you imagine someone attempting to blow in the inlet nipple on the tank. lol
UPDATE!!!! It finally started after a arm numbing time period of pulling lol. I put all carb settings back to stock and it finally started guess she just needed some time. Thanx to all of u guys for your help it is much appreciated.
now that would be a picture to see....... lmao
It would read ok I did as you said and all it did was make bubbles I don't get it ? Any other ideas?? :duh::resp:now that would be a picture to see....... lmao
