Team Losi servo arm
Dreadnaught
Diesel Powered!
Pinckney Michigan
alright, i bought a new servo arm from the new (crappy) hobby shop. its a LOSA99030, and i cant find a dang screw to fit into it for connecting the steering bell crank arm to.
please help.
thanks in advance,
Kyle.
Drum with the aluminum servo horns I have used in the past I have always drilled a bigger hole for it where it barely fits then put a nut on the other side to hold it on....just me though, only used a metal one once though
Dread, I've done the same thing as Parker mentioned and haven't had any problems. I've done it to an alum. servo arm and a plastic servo arm once. And both worked great. Hope this helps too.
alrighty, guess its a trip to the hardware store. thanks for your help parker, and xtrem!
Dread, before you do that, look and see if you have some extra 3mm x 15mm screws layin around along with a 3mmm nut. I'm sure you already have a 1/8th in. drill bit. That's all you need to make it work. A 3mm screw will fit snuggly in a 1/8th in. drilled hole. That way you don't have to much access play.
