ofna linkage
esims
:Radioactive: could someone tell me the number on the ofna linkage and why you change it also this half tank lean thing is killing me i saw a tank on new era racing does it work ok this is a new ballgame for me use to have jato 3.3 this is all different and much more fun.
good call on hirisk's ofna thread sunk......ive passed tht 1 out many times.
as for WHY; it will give you more adjustability & you can set your brakes to grab harder.
1/2 tank lean: the stock tank mounted in the stock location is a bad design because the fuel is lower than the carb. Yep. although most prefer a mid tank, the new era's should to the trick for short $$
http://www.neweramodels.com/item.cgi?session_id=mwdvqtvagmogbxkryoxrogwpkqrhhuiq&part_id=1853
http://www.neweramodels.com/item.cgi?session_id=mwdvqtvagmogbxkryoxrogwpkqrhhuiq&part_id=1704
i just did the ofna tank mod from new era (side mount) and it has improved my tune stability greatly, it holds a tune right to the last drop of fuel in the tank. the step or L shaped stock tank is more to blame than the tank being located under the carb for the half tank lean. check this tread out for a nice clear explanation
MotoPsycho's Meager Mod's - Tank 1/2 lean EXPLAINED
should help you out
should help you out
I agree that the L-shape is not a great design & that the ofna tank will help, but the 1/2 tank lean is product of physics, not tank geometry. r/c vehicles do not have a fuel pump therefore it is gravity that flows the fuel from the tank to the carb. once the fuel level drops to 1/2 tank, the pressure line simply can not produce sufficient psi to carry the same amount of fuel uphill to the carb.
When bashing with Bankrupter, his pressure line became disconnected, but his mill kept running because his 250cc mid-tank is not below the carb & gravity continued the flow of fuel. Same would hold true if you tried to siphon fuel from your 1:1 vehicle: place the container below the vehicle's fuel tank & fuel will flow if you blow in some pressurized air......place the container higher than the vehicle's tank & gravity will keep the fuel in the vehicle's tank as it is lower than the container.
Do an experiment.........mock up a set of mounts for your stocker tank that make the bottom of the tank flush with the carb & see what happens to the 1/2 tank lean.
.........or............
mock up a set of mounts & drop your ofna tank lower than the carb & see what happens.
