How long has he had the mill I wonder how long its going to last be that temp all the time Did he ever replace the o-rings on the low end or top end needles might want to check into thatLOL you guys are going to laugh at my cousin--he runs his HPI .25 @ 300*-320* if he riches it up it doesn't run for anything. This thing has lots of power and a good strong smoke trail at those temps, and it is sealed. Any thought on this. My self try to keep my temps under 280*, I watch and listen to the engine more than worry about temps though.
HI Guys. Q? Big COLD front in PNW (rare) anyways Got About 5" fresh powdery snow in the hood. So beins I had no choice bolted stockers on front and paddle tires on the back and took the savvy out. (finally) I'm running a Axial .28, it seems to be running strong, good smoke. Even pulling wheels up and carryin, but even after cycloning at full throttle. The temps barely reaching 100 degrees. I realize It's cold but could I maybe need to lean it or should I leave it. I'd like to get more out of it if possible. Ticks the neighbor with the new revo 3.3, the more the better. White stuff won't be around long and i'd like to abuse it as much as possible.
Stop right there do not lean it out to raise thoes temps THATS NOT GOOD MAN if its cold out u need to richen it if anything yea I said richen it up ....put some tin foil on the head of it to help thoes temps but don't lean it out cold air is more dence and more air means more fule
