LST Shocks
tractorman
Does anyone know if or how you can get the LST shocks to fit on the RPM a-arms for the Savage X 4.6? If so where can I get the adapter plate for the a-arms? Is there anything that you need to do on the shock tower or do they just bolt on?
I was just lookin at jcam54's build with the lst shocks and I was wondering what does the adapter plate on the lower a-arm do? Is there any reason why you can't mount to the existing shock mount on the lower a-arm or does the shock hit something?
you have to move the shock out due to the upper mounting locations. innovative r/c is a good place to get the conversion kit, and as far as i know, you have to run savage 25 style lower arms. (the ones with mounting holes on top and bottom.
I picked up 1/4 inch alloy spacers and smaller ones to fill the shock mount holes for a bolt to go thru it with out crushing the pocket. I Bolted them to my x arms on my basher fine. I used the stock lst uper mounts for the shock hole as it is larger than a single screw. It can be done. But all of the kits on the market are for the standard savage arms.Or so I have seen<---- idk here! If you want some pics LMK Ill get them up for you. Ive yet to full out run this set up /mod but from all I can tell it will work fine.
Hey, Thanks to everyone so far for the replies. Bankrupter, if you could post some pictures that would be awesome. Or even if you send me a PM through here then I can reply back to you with my e-maill address to send some pictures to. Although I'm sure everyone else would like to see the pics as well. I'm kinda computer stupid so when you said "LMK me" what does that mean?
OK ill put them together for you. LMK = Let/ Me/ Know you will see a few things like this in the posts. IDK or I don't know if we have a thread on abbreviations here but if so Ill link you to it. Or could anyone else? If so thank you.
~Justin~
HERE you go. According to the description they work with the RPM arms.
This is almost Identical to what I had come up with Nice find X!!
The only difference I can see is at the shock pocket in the arm itself. I did this a Lil different. I'm still looking for good pics I swore I had them on photo bucket but no. Looking thru a few memory cards now.
Sweet!! Thanks X!! Also thanks for the abbreviation updates too!! I would still like to see those pictures there Bankrupter if you can find them. I think I'm going to phone my LHS right now and get a set of shocks on the way. Does everyone else find this a decent upgrade over the stock shocks?
this is off but on topic about the shocks https://www.hpisavageforum.com/forums/showthread.php?t=6873
it was really a Low CG ? but has a few more posts on the shocks themselfs. My racer is posted there. But set up the other way. PM me you email I have a pic for you but its not one I'll post. The Bench is a mess!!! I thought I took allot more but I cant find them. My buddy has my x in his truck Ill have it back tonight and Ill snap you more.
