time for a new motor
gtbasher
New Member
there was a picco 27 in it. just got a savage 25 LE off ebay.got burned motor worn out , told other wise,o'well.thinking about picco 26.any sugestions ?
Hey GTbasher, the picco26 is an awesome motor i rebuilt the last one i had after about 3 gallons, i got it used from a member in New York, it still had great compression when i rebuilt it. Even before the rebuild it would pull a wheelie from take off, ask Chunky he saw many of them. I couldnt tell which clutch to use as i only used two different types, one being the old stock 2 shoe, and the the Fiorini turbo sliding clutch, ask HOP about them he got me into it.
thanks guys.I was kind of bummed I never got the picco 27 going,but I just got a new roto starter and would like to stick with that start system if possible. I was also considering an OS motor.Will the picco 26 bolt into the same motor mount as the picco 27.Thanks again for the input, GT
i would like to make a sug.. i have the surefie .32 in my savage this mill totaly rocks man 3.6 hp at the flywheel and 38000 rmp pulls whellies and mid throtle with a 47/17 spru/clutch bell comp check into it and keep us posted on what u get later man
thanks for all the input.not sure which one I'll get yet but I'd like a direct drop in and be able to use my brand new roto start. I have a nitro rustler for sale with .15 that is a great motor.stays tuned never had a problem. I also thought of the traxxas 3.3.will it fit and can I use my roto start.thanks again for the help. GT
the oz is a drop in also the surefire is to all u have to do is twist the carb then your ripping man WIll the 3.3 fit in what????????
why not a K4.6? may sound silly but I`m having so much fun with it.
my k4.6 has smoked 25-30 liter of tornado 25 and it`s still running fine.
( a gallon is somewhere around 4 liter but I`m not exactly sure )
I got a nova head which I`m gonna fit but without it it already had so much power, all you gotta do is solve the 1/2 tank lean issue if you didn`t solve it already.
2.9 hp, 39.000rpm max.
enough power to turn it upside down with a little too much throttle and a 47/17 spur/clutchell combo, wheeliebar or no wheeliebar!
I wanted to put my sav back together today but the LHS didn`t have shims formy diffs so I`ll have to wait til he has them.
I`m in the middle of a rebuild but I desperately want to know how the engine performs with a nova head, when I know it I`ll take it apart again and continue rebuilding & modding.
my little cousins 3.5 is running sooo mean since I fitted it with a nova head, it reaches full speed in 20 meter and punches wheelies on command.
